spring replacement on GL
Posted: Fri Apr 06, 2012 12:44 pm
got to change the front spring on a GL150
was given a spring to fit, which is about 40mm longer than the one that came off.
so, guessing it's for 8" wheels, and will therefore be stiffer.
it looks a bitch to fit, which i expected.
and looks like it will be pretty coil bound once on, or will just bottom out the damper...
is this worth pursuing...?
is there a better alternative to stiffen the front end; the bike [not mine] has a rack full of lights on the front, so could benefit from some uprated suspension.
I was thinking of cutting the new spring down by a couple of coils and reshaping the end to fit the top plate... ?
any tips or recommendations gratefully received
