Page 1 of 2
ts1 225 to 240
Posted: Fri Apr 06, 2012 11:27 am
by roadrunnerian
hi,
which way is the best to convert my ts1 and would i get any big advantages thanks
Re: ts1 225 to 240
Posted: Fri Apr 06, 2012 11:31 am
by Andy Pickering
Red runs a TS 240 built by Jase Frost
Re: ts1 225 to 240
Posted: Fri Apr 06, 2012 11:41 am
by RICSPEED
simplest is to look at using a long stroke crank 60mm or 62mm and keep the 70mm bore but port timings will need to be corected and base packers / toping and tailing of the barrel needed ,the larger stroke cranks require case to be machined to clear the rod end
Re: ts1 225 to 240
Posted: Sat Apr 07, 2012 8:50 am
by roadrunnerian
Thanks for info guys sounds like what i,m after more torque nice one
Re: ts1 225 to 240
Posted: Sat Apr 07, 2012 9:32 am
by bazman
The easy option i found was to fit a 60mm crank which did not require casing mods , 1mm basepacker/gasket from AF, no head gasket and dowl'd head. Vast improvement to tourque over the 58mm crank, still runs 4.8 gearing and a race pipe and pulls very well.
Re: ts1 225 to 240
Posted: Sat Apr 07, 2012 12:18 pm
by Train Driver
Mb used to do 64mm cranks and last year i think i read about 66mm & 69mm cranks
I'm no expert but was told once over 60mm a 120mm rod was needed to stop vibration ????
Re: ts1 225 to 240
Posted: Mon Apr 09, 2012 9:34 am
by red
Andy Pickering wrote:Red runs a TS 240 built by Jase Frost
It's a 230
Re: ts1 225 to 240
Posted: Mon Apr 09, 2012 8:41 pm
by scoot gp
Recently done mine to a 240 (238) for this season, spec is:
71mm touring tune by chisel speed running no gaskets
60-115 mb crank
30mm mikuni
Taffy pipe
m tech
Dynod at 21bhp at chisel speed
fuel consumptions good and sits nicely at 70-75 with very little vibration and plenty of torque.
Re: ts1 225 to 240
Posted: Mon Apr 09, 2012 8:57 pm
by scoot gp
eden wrote:scoot gp wrote:Recently done mine to a 240 (238) for this season, spec is:
60-115 mb crank
30mm mikuni
Taffy pipe
m tech
interested what the torque figure was when it was dyno'd
Graphs still in the car, i'll take a look in the morning.
Re: ts1 225 to 240
Posted: Tue Apr 10, 2012 9:03 am
by soullad
bazman wrote:The easy option i found was to fit a 60mm crank which did not require casing mods , 1mm basepacker/gasket from AF, no head gasket and dowl'd head. Vast improvement to tourque over the 58mm crank, still runs 4.8 gearing and a race pipe and pulls very well.
this also is a 230
unless you running 71mm piston.
