Fitting Lucas Pathfinders
Posted: Tue Apr 03, 2012 9:16 am
Hello all my 1st proper post and it’s regarding the fitting of Lucas Pathfinders.
I’ve searched previous post but require a bit more information.
My main dilemma is whether my Lambretta is AC or DC powered. It has electronic ignition and the system looks the 1st diagram here labelled “wiring diagram for standard non battery electronic –
Do I need DC or can AC be used for Pathfinders? I have a replacement “xenon†bulb in my headlight and an LED taillight, both of which work fine.
So the whole AC/DC thing stumps me.
Secondly, I understand the mounting bolts need to be longer. Will a hollow threaded bar suffice with nuts either end? Is the size M10 or similar?
I've come across this which may be of help to others.
Are there LED replacement bulbs available for Pathfinders to reduce the power consumption?
I have my lights wired through the Series 3 lighting switch, but I also have the key ignition switch. Only the cut out is used and I was going to use the other positions for controlling the Pathfinders. Is this feasible?
Any wiring and mounting information regarding Lucas Pathfinders will be gratefully received. And I thank you in advance.
The whole AC / DC thing baffles me. I'm used to DC current on cars and I'm fairly clued up on this. But AC ???
I'll ask questions about this on another post to keep thing separate.
Shaun
Shaun
