Final drive bearing loose?
Posted: Thu Mar 29, 2012 1:07 am
I have started to build up my TS1 motor on indian casings, I built up the bottom end to shim my gearbox and found my final drive bearing to be kinda loose fitting. There is no side to side play but it takes almost nothing to knock it back out. Once the bearing retaining plates are on it will not move. My concern is this, if it is loose fitting will gearbox oil find it's way out between the bearing and the case? Can I just use a sealant around the bearing? It's a new case and a new Casa bearing.
Thanks
Thanks
