90 engine rebuild ~ kickstart pinion not disengaging
Posted: Wed Mar 28, 2012 10:04 pm
rebuilding a vespa 90 engine
change to a 4 speed box
going ok [if a little fiddly, i am used to working on lambretta engines]
but when the cases are together, the kickstart pinion is not being pushed far enough towards the clutch, so is clicking on first gear...
compared the original 3-speed cluster, measures up the same.
it seems like the quadrant either is not over far enough, or doesn't have enough metal on it to retain the pinion out of the way... if the kickstart shaft is pulled outwards it clears, but that will just move back in...
I could change the quadrant maybe? or weld a bit on the existing one ??
or have i missed a trick ?
the spring behind the pinion goes straight onto the bearing ? with the dished washer on top of that ??
edit ~ sorry ^ meant other way round, washer first - concave side towards the bearing ? - then the spring
