px indicators
ducksta
just done a full rebuild started the scoot got horn lights back lights brake lights front indicators both sides but not rear any quick clues what to look for will check earths again on both pannals, everything is new ie pannal wiring and inicators also the frame sockets any help would speed things up as with the fuel shortage dont want scoot ticking over all day trying to find the problem lol
fraserp200e
Main scooter: 1988 MotoVespa TX200
As its just been rebuilt (and I'm guessing resprayed) check where the panel earths to the frame, not just where the indicator earths the panel. There should be a metal to metal contact (no paint) at the wee spring clip on the panel and catch on the frame. If that's all good check the switch on the handlebars. You might have trapped / nicked the cabling when you put it in the frame.
I've had both these snags on mine at different times. Hope this helps. Remember to post up when you find the snag.
1983 Vespa PX125
1984 MotoVespa P200E
andyt5
flasher unit. had the same problem on mine. only front working. swapped the flasher unit from my other scoot and problem solved.
ducksta
cheers lads will try both ideas
