Mugello 225 enquiry!!
Posted: Wed Mar 21, 2012 11:51 pm
Hi all, I am thinking about buying my brotherinlaws Li 225 special. My biggest reservation is the engine, or more specifically the Mugello 225 kit that's fitted to it.
The engine specs are as follows:
Sil 200 casing, Mugello 225 (not sure what model but the engine was built July 2007), AF Rayspeed 58mm crank, JL3 Pipe, Delly 30mmm PBHB carb with remote filter. It also has taffspeed clutch, IWIS chain, SKF bearings, Rolf seals, MBD chain guide & electronic ignition.
It has always had a problem with boging down badly at low throttle openings and has had the carb & exhaust changed. If you don't give it a fair few revs on take off the engine will either stall or bog down badly and take a while to start running cleanly again. Once your up and going the scoot seems to run OK, but you are always blipping the throttle at lights and it's not the nicest scoot to ride in traffic. Fuel consumption is also pretty bad.
On reading the various forums it would appear that the Mugello 225 is not a very highly regarded kit "out of the box" (and I am sure this would be basically an out of the box motor). I guess my question is - can I fix this bad low speed running without major surgery or expense (I am in Perth, Western Australia, so I can't just pop along to the local Guru as you guys in the UK can). The general opinion seems to be that you need a 60mm crank to make it work well (why is this?), together with cylinder base packing plate to alter the port timing and head machining to get the proper squish after said crank & baseplate mods.
I don't mind working on the engine myself, including things like matching ports to manifolds etc and would love to draw on the combined experience of the forum to see what solutions are available, preferably the cheaper the better. Or is the Mugello 225 a rite-off!
