Avanti kit question
- registered user
- Main scooter: The Biriani Bullet
- Contact:
Building up a new 200 casing and thinking of going down the Avanti route. Are the transfers at the base of the cylinder much larger than standard? I ask so that I can blend the transfers on the casing to match the cylinder, but don't know how much bigger, if any, they are. Have a mate who's running one in and have asked for one of the extra base gaskets supplied to use as a template.
do they need blending; is it the biggest restriction that limits the kits performance and if not matched will show up on the rolling road or will it perform the same if left untouched,
muppet
muppet
C’est la vie
- registered user
- Contact:
Don't know, else I wouldn't have asked. Just that it seems sensible, before putting all the guts and bearings in, to make sure there is a smooth flow of gasses from the crankcase into the cylinder :wtf:Muppet wrote:do they need blending; is it the biggest restriction that limits the kits performance and if not matched will show up on the rolling road or will it perform the same if left untouched,
muppet
- registered user
- Main scooter: Lambretta
- Contact:
but you'll want your crank out while you do it
- registered user
- Contact:
Exactly. That's my mate's engine which he has already built. He just sent me the photo to show how much needed blending. He's sending me one of the spare base gaskets as a template.
- registered user
- Main scooter: Lambretta GP
- Contact:
It looks good but the difference is minimal compared to other aspects (CR, exhaust/expansion, ign timing and general bolting it together properly).dapper wrote:Don't know, else I wouldn't have asked. Just that it seems sensible, before putting all the guts and bearings in, to make sure there is a smooth flow of gasses from the crankcase into the cylinder :wtf:Muppet wrote:do they need blending; is it the biggest restriction that limits the kits performance and if not matched will show up on the rolling road or will it perform the same if left untouched,
muppet
Do it if the motor is already in bits, or you have time on your hands, otherwise wait for its next rebuild.
with the wide ex port so large is the blend possible to all after maket pipes; or close fit needing little work; or is this where time will be well spent blending, ?Avantone wrote:It looks good but the difference is minimal compared to other aspects (CR, exhaust/expansion, ign timing and general bolting it together properly).dapper wrote:Don't know, else I wouldn't have asked. Just that it seems sensible, before putting all the guts and bearings in, to make sure there is a smooth flow of gasses from the crankcase into the cylinder :wtf:Muppet wrote:do they need blending; is it the biggest restriction that limits the kits performance and if not matched will show up on the rolling road or will it perform the same if left untouched,
muppet
muppet,
C’est la vie
The exterior of the exhaust port is exactly the same a standard big bore exhaust gasket, it was made like that so most stubs would be able to fit!
