Page 1 of 2
px125 longer gearing
Posted: Sun Mar 18, 2012 6:23 pm
by Ivan_200
Hello, I'm building a px125/150 engine with a polini 177kit. What can be done to longer the gear ratio (polini/malossi primary drive kit?) and can I put a stock px200 clutch on it to get a few kmh more? Thnx 8-)
Re: px125 longer gearing
Posted: Sun Mar 18, 2012 6:42 pm
by goldeneye
a P200 clutch wont fit, because the drive cog is 23 tooth , and the most you can fit on px125 primary drive is a 22 tooth. if you fit a polini 177, i"d go for a 21 tooth clutch, you dont have to buy a full clutch , just a 21 tooth cog to fit on your clutch.
Posted: Sun Mar 18, 2012 6:43 pm
by goldeneye
if its a 150, the gearing will probably be ok as is.
Posted: Sun Mar 18, 2012 7:22 pm
by Ivan_200
goldeneye wrote:a P200 clutch wont fit, because the drive cog is 23 tooth , and the most you can fit on px125 primary drive is a 22 tooth. if you fit a polini 177, i"d go for a 21 tooth clutch, you dont have to buy a full clutch , just a 21 tooth cog to fit on your clutch.
my friend fitted a px200 clutch on a similar engine (i think was a px150) so i'm confused.... can i expect real 120-130kmh with 22 tooth clutch?
Posted: Sun Mar 18, 2012 8:38 pm
by goldeneye
he will have had a p200 primary drive fitted. a "p200" clutch is just a normal clutch, its the drive sprocket that makes it a "p200" clutch. whats 130kmh? 75mph? the answer is probably "NO" it depends on the rest of your tune, carb/exhaust/cut crank/porting etc. at the end of the day, its a budget kit, dont expect it to be an R1. loadsa lads round here run kitted PX"s, mainly for monetary reasons, and i keep having to tell them that its cheap tuning, dont expect the earth, expect 5-10 reliable MPH .
Posted: Mon Mar 19, 2012 12:42 am
by Ivan_200
excuse me for my bad english in engine parts terminology :lol: so let me reform the question:
what teoretical top speed on a polini177 with bigger carb and lefthand pipe would i have with the 23-64 polini/malossi kit, and what with just a clutch with 22 or 23 teeth sprocket on standard gearbox? thnx
Posted: Mon Mar 19, 2012 6:19 pm
by Train Driver
Just picked up my PX125 fitted with a DR180 kit from alan (diablo moto) who had fitted a 22 tooth sprocket for me, since i am slightly large it requires a few revs to get away but pulls ok.
On the M1 i was cruising at 6000/6500 rpm and at one point was doing 7000 :shock: :shock:
Alan says 22/68 = 10mph per 1000 rpm
Very happy :bouncing: :lol: :bouncing:
Posted: Mon Mar 19, 2012 9:04 pm
by col68
I have a 1982 px125e with a 166 malossi on 21 tooth malossi up gear kit 28mm delly 15bhp the nice lady at taffspeed helped me out, revs to 7000 with simonini pipe on . My gearbox was very short before had this work done !!
Posted: Mon Mar 19, 2012 11:05 pm
by Ivan_200
Train Driver wrote: Alan says 22/68 = 10mph per 1000 rpm
so 22 teeth sprocket is the way to go :geek:
col68 wrote:I have a 1982 px125e with a 166 malossi on 21 tooth malossi up gear kit 28mm delly 15bhp the nice lady at taffspeed helped me out, revs to 7000 with simonini pipe on . My gearbox was very short before had this work done !!
previous p125 engine i had a polini 177 on had a terribly short gearbox, but it pulled like hell to about 95kmh :lol: smoked out my friend's vespa gts 200 with malossi multivar and intake/exhaust mod 8-) now i want to race my other friend's gilera runner 180sp, so i need that top speed :baddevil:
Posted: Thu Mar 22, 2012 5:23 pm
by tha83
Train Driver wrote:Just picked up my PX125 fitted with a DR180 kit from alan (diablo moto) who had fitted a 22 tooth sprocket for me, since i am slightly large it requires a few revs to get away but pulls ok.
Wait! Hold the presses! What's all this then? 70 MPH bloody hell! I just spit coffee all down my shirt, I'll send my dry cleaning bill. :lol:
(inside joke)
