clutch problems
Posted: Tue Mar 13, 2012 10:04 pm
Hi just finished fitting a mugello 186 kit ,new bearings, seals, crank ,chain etc .The scoot starts up and ticks over great.The only problem is when the clutch is pulled in
and gear selected it stalls,if you rev it ,it will move but soon dies. I,ve tried different cable adjustments to no avail . When rebuilding i replaced the old spring type rear sprocket with a scooter restos solid bush type ,used the original spider ,pressure plate and clutch steels ,with new corks and uprated springs .Theres enough
room between plates when compressed. The clutch lever is quite stiff ,even when i used an old set of springs
I presume i will have to replace the spider and pressure plate.....more expense .The corks are the recommended 14mm and the top steel is the 2.5mm li type
Cheers for any advice
