Page 1 of 2
Oil Level sight plug
Posted: Fri Apr 03, 2009 8:28 pm
by Dazza
Do these fit where the filler plug is then fill via breather until the oil is just visible in the sight?
Or am I being a pleb?
Re: Oil Level sight plug
Posted: Fri Apr 03, 2009 8:31 pm
by paulmgreen
eh??????
Posted: Fri Apr 03, 2009 8:46 pm
by Dazza
I'll start again....
Just bought one of these:
Does it fit in place of the gearbox oil filler plug , then top up oil via the breather so that the oil is just showing in the sight glass.
Surely that makes sense now Paul???
Have a couple of glasses of wine to help...
Posted: Fri Apr 03, 2009 8:55 pm
by sean brady scooters
spot on mate............
the sight glass plug ,is the one nearest front of scoot................
if oil is visable in this .......then its fine.....................
Posted: Fri Apr 03, 2009 8:56 pm
by Dazza
Cheers sean
Posted: Sat Apr 04, 2009 4:52 pm
by corrado
I use the breather hole to fill the crankcase. With the scooter level and the centre hole plug removed you fill with oil until it starts leaking from the centre hole. The plug with the window is the cente one of the 3, but with scooter level you shouldn't actually see any oil. If you can see oil when level then it's over-filled surely (no don't call me Shirley jokes please). Off the stand and tilt scooter slightly towards you then the oil should come into view. Then again I do know feck all.
Posted: Sat Apr 04, 2009 7:06 pm
by noggin1969
You,ll find they get all crapped up and stained anyway so you can't see nowt
Posted: Sat Apr 04, 2009 9:40 pm
by byron
noggin1969 wrote:You,ll find they get all crapped up and stained anyway so you can't see nowt
oh great. i just bought one too.
wonder why they become so, they're fairly standard on motorbikes
i did need another level plug anyway...
Posted: Sun Apr 05, 2009 6:56 am
by Dazza
I have a solution! When it gets dirty , take it out and clean it
Posted: Sun Apr 05, 2009 8:34 pm
by RBG
Dazza wrote:I have a solution! When it gets dirty , take it out and clean it
Anyway it will look trick!
