210 spaco 28 mil jetting
Posted: Sun Mar 11, 2012 9:23 pm
by Danger
malossi 210 , casings matched to suit kit , malossi head , s.i.p evo jl lefthander pipe , 28 mil spaco carb delly copy what jetting should i be running , so far its got
slide 40
x7 neddle
main 130
choke jet 45
atomiser av268
idle jet 50
float needle valve 200
Re: 210 spaco 28 mil jetting
Posted: Sun Mar 11, 2012 10:12 pm
by goldeneye
mine was..AV264, X7 second clip from top, 55 pilot, 70 choke, 40 slide, main 132 mixture two turns out, 17 degrees timing. running a malossi rubber to the frame, no filter. still going well now. that was on a 30mm dellorto, JL righthand.
