oil in carb box ~ now with added solution
Posted: Sun Mar 11, 2012 3:26 pm
changed the crank seals on a standard 2007 PX125
all back together and running
went on a 5 mile ish ride, all fine sitting on the stand;, inside the carb box is clean, but then looking in there a few hours later, there is quite a bit of 2 stroke oil at the back, cleaned this up, but then again this morning, more oil has appeared...
had the carb off and cleaned it out more than once, refitted with genuine piaggio gaskets, the oil feed in the carb vent is free and there is evidence of oil, the nut on the oil feed is tight and no signs of any leaks...
So not sure what to check next... could the oil pump be delivering too much oil..?
Not sure where the oil is coming from when the engine is off overnight, and the oil tank is lower than the carb...
thanks
thanks
