exhaust manifold fixing
- Toddy
- Main scooter: Lambretta Series 1
I use the extended nuts with wirelock on mine also i have used someones idea of a tab washer which you can bend up to help lock the nut i'm afraid on exhausts with the copper gaskets they always need a tweak as the gasket compresses until settled after a few miles , i check the nuts regulally after each rallyTosh wrote:very mad they just keep coming undone sick of having to keep re-tightening them,wasting gaskets whats the best ways to overcome this problem, wired nuts/wired allen key?????
like this not my idea but something that was shown to me by taffspeed in the mid 80.s and used on our gp4 race scootersToddy wrote:I use the extended nuts with wirelock on mine also i have used someones idea of a tab washer which you can bend up to help lock the nut i'm afraid on exhausts with the copper gaskets they always need a tweak as the gasket compresses until settled after a few miles , i check the nuts regulally after each rallyTosh wrote:very mad they just keep coming undone sick of having to keep re-tightening them,wasting gaskets whats the best ways to overcome this problem, wired nuts/wired allen key?????
- twenty eight
Agree with toddy i use extended nuts with wirelock,andy francis sells the ones i use a tenner i think good investment
joespeed
shocky wrote:like this not my idea but something that was shown to me by taffspeed in the mid 80.s and used on our gp4 race scootersToddy wrote:I use the extended nuts with wirelock on mine also i have used someones idea of a tab washer which you can bend up to help lock the nut i'm afraid on exhausts with the copper gaskets they always need a tweak as the gasket compresses until settled after a few miles , i check the nuts regulally after each rallyTosh wrote:very mad they just keep coming undone sick of having to keep re-tightening them,wasting gaskets whats the best ways to overcome this problem, wired nuts/wired allen key?????
what are we looking at here?
half a tab washer from a chain guide,used on the exhaust nut.
- Andy Pickering
- Main scooter: GP
Both Toddys way and Shockys way actually work a treat, fitted extended nuts with wire from David Blythe (where has David gone ?), and the lock washer way on a mates, like I say both work a treat, Joe, get to specsavers my old friend
joespeed
andy,just been to spec saver and got two pair,but i think that they are two strong when worn at the same time!Andy Pickering wrote:Both Toddys way and Shockys way actually work a treat, fitted extended nuts with wire from David Blythe (where has David gone ?), and the lock washer way on a mates, like I say both work a treat, Joe, get to specsavers my old friend
thats ok with the tab washer,still like the idea of the short stub with slip on u bend,long bolts wired together.
