Page 1 of 2
fast flow tap
Posted: Fri Apr 03, 2009 12:45 pm
by jonbus
does the tap need a fibre washer where it connects nut onto the tank? the one i have bought does not have one.will the tap seal ok when the plastic base it tightend against the tank thread?
Re: fast flow tap
Posted: Fri Apr 03, 2009 1:37 pm
by eibargum
My last 2 have had a rubber o ring for a seal.
Re: fast flow tap
Posted: Fri Apr 03, 2009 2:26 pm
by corrado
Some use a plastic washer and some have the washer as part of the mesh cover, so the answer is..... not always.
Re: fast flow tap
Posted: Fri Apr 03, 2009 7:32 pm
by jonbus
cheers corrado,i have an escort rear shocker fitted so hopefully the extra length of the shocker will make the tap fit easier,i hope
Re: fast flow tap
Posted: Fri Apr 03, 2009 7:38 pm
by sean brady scooters
its been mentioned before,..........but please check that your fast flow tap is in fact a fast flow item,because.........some just arnt...........even though they are sold as such............................
best checked by the old method of timing the filling of a pint glass etc...........
Re: fast flow tap
Posted: Fri Apr 03, 2009 8:31 pm
by Dazza
I can concur with Sean here, I must have bought three or four before I found one that was any good - camlam was the answer - ebay aint
Re: fast flow tap
Posted: Fri Apr 03, 2009 8:44 pm
by J1MS
Just bought a fast-flow tap rear exit from Camlam, "Has any one used one of these and are they any good", as I will be fitting it as soon as I can get back in the garage......... Doctors what do they know ?? Surley I can play in the garage and get better at the same time...
Re: fast flow tap
Posted: Fri Apr 03, 2009 10:05 pm
by RBG
J1MS wrote:Just bought a fast-flow tap rear exit from Camlam, "Has any one used one of these and are they any good", as I will be fitting it as soon as I can get back in the garage......... Doctors what do they know ?? Surley I can play in the garage and get better at the same time...
I'm using one! very good.
Re: fast flow tap
Posted: Fri Apr 03, 2009 10:06 pm
by J1MS
^ THANX^
Re: fast flow tap
Posted: Sat Apr 04, 2009 12:44 am
by byron
RBG wrote:I'm using one! very good.
me too, makes for a nice fuel pipe route.
although not so impressed with the low fuel warning light. I failed to see it and ran out of fuel for the first time in years [luckily at the top of a hill with a petrol station at the bottom
] , which kind of defeats the object of having one... I think I'll replace the led with a more noticeable bulb.
