jimmers, LTH, MB manifold
Posted: Mon Mar 05, 2012 9:35 pm
by sydduckett
I need more clearance between my vhsh carb and the panel to get a marchold filter on (the smallest i can find) Its an rb20 with the standard AF manifold the kit came with. Im already running offset cones and need at least 10 more mm. This could be a combination of the angle of the Carb and it sitting further back.
Does anyone know which of the 3 i have mentioned sits the farthest back? Im also hoping to get some more clearance by using a shorter mount, currently have the Andy francis one with 2 jubilee clips.
Ta
Sef
Re: jimmers, LTH, MB manifold
Posted: Sat Mar 10, 2012 1:03 am
by leigh
Im running a jimmers/LTH style on mine. what panels do you have i have Li on my RB will measure the gab for you if this helps. carb defo sits back more
Posted: Sat Mar 10, 2012 9:19 pm
by sydduckett
leigh wrote:Im running a jimmers/LTH style on mine. what panels do you have i have Li on my RB will measure the gab for you if this helps. carb defo sits back more
cheers Leigh, im running a 30m delorto vhsh, i reckon i have about 10 - 20m gap at the mo but havent been able to measure exactly as i havent had the pipe off. Ill take it off tomorrow to get an exact measurement. I understand Jimmers is shorter than the AF one and sits at a different angle?
Iv had no joy from pm jimmers on here so if its alright can you let me know where you got it and how much?
ta
sef
Posted: Sat Mar 10, 2012 11:37 pm
by leigh
This is the one im using
http://scooterotica.org/forum/viewtopic ... 12&t=12359
part is quality, arrived quickly. Carb sits further forward and further back. Think it was just over a hundred quid, with this one the reeds sits a couple of mm higher
Leigh
Posted: Sat Mar 10, 2012 11:55 pm
by cezeta
i know its not the question but you will get more clearance with a tmx35 and better performance with a breath sweet filter than any of the small pancake filters. on the ts1 i used a jimmers inlet and machined a bit more off of the front too.
Posted: Sun Mar 11, 2012 2:12 pm
by leigh
Took some pics hope they help.
some with LI style panels and also one with a GP
