Reinforcing Flywheel
Posted: Thu Mar 01, 2012 11:51 pm
by diesel
I have read the recommendations made on the Supertune website regarding the upgrading of components prior to installation of the Avanti tt3 and I am concerned that the Flywheel needs reinforcing and at a minimum I imagine this would mean welding bits to other bits.Has anyone done this or drilled and replaced the rivets with bolts? and if so is there any advice you could offer? Am I better off buying a pre-strengthened one?(I am currently using a sil GP flywheel)
Cheers
I have done a search on this topic to ensure this question has not been asked in living memory,if I have failed to input the right combination of keywords in the search options I apologise for the distress I will be causing to those of a sensitive disposition.
Re: Reinforcing Flywheel
Posted: Fri Mar 02, 2012 10:30 pm
by wack 63
Posted: Fri Mar 02, 2012 11:39 pm
by diesel
Thats the job Wack thank you
Posted: Fri Jul 20, 2012 10:58 am
by dapper
Can't understand why that flywheel is welded on the inside of the boss and not on the outside, as it would be easier to prevent weld splatter getting on to the magnets
Is it advisable to have it welded on the inside as well as the outside? And why is the very small section of the boss welded too when it is a solid piece?
Posted: Fri Jul 20, 2012 3:00 pm
by Lamaddict
dapper wrote:Can't understand why that flywheel is welded on the inside of the boss and not on the outside, as it would be easier to prevent weld splatter getting on to the magnets
That's a good point.
I wonder if the Jap motorbike world could shed some light on this flywheel weakness.
Posted: Sat Jul 21, 2012 6:17 am
by joeswoonara
cant answer the bit about the boss welding .....but the bit about spatter on magnets
as someone who tried to weld the boss
as soon as you put a welding rod near the boss the magnets pull the rod away from where you want to weld to somewhere you don`t want to weld with with somewhat comic results (how i laughed ).........i then discovered the "pro`s" shield the magnets in lead ..................which protects them from any spatter !
Posted: Sat Jul 21, 2012 6:20 am
by joeswoonara
oh and i always just use domehead set screws and nylok nuts and washers to replace the rivets on my Indian flywheels never had a problem
Posted: Sat Jul 21, 2012 9:29 am
by coaster
Lamaddict wrote:dapper wrote:Can't understand why that flywheel is welded on the inside of the boss and not on the outside, as it would be easier to prevent weld splatter getting on to the magnets
A guy had one just like that at the Flying 8 Balls Rally the other week only it had cracked around the weld and all the rivets were loose
It was suggested at the time that it should have been TIG welded, any thoughts?
