Chain Tensioning on a S3 TV175, is this too tight?
Posted: Thu Mar 01, 2012 11:23 am
by kejj
kejj wrote: 5-6mm wasn't easy obtainable. especially since the chain in some position moved more on the lower side than the tensioner side.
I think I've done good enough but I have difficulties to know what's right.
What do you people think of these toleranses?
http://scooterotica.org/forum/viewtopic ... 1&start=50
Re: Chain Tensioning on a S3 TV175, is this too tight?
Posted: Thu Mar 01, 2012 11:42 am
by dapper
Kejj, you need to turn the rear sprocket so that all the slack in the bottom of the chain is taken up. Then, with the top tensioner just loose enough to slide up and down by hand, move it up against the chain and check that you have 5-6mm slack up and down movement between the front of the tensioner and the front sprocket. Once achieved, tighten up the tensioner securing bolts.
Posted: Thu Mar 01, 2012 5:27 pm
by psychedelicropcircle
...and real men go in bear handed :fb:
Posted: Thu Mar 01, 2012 10:57 pm
by wack 63
Do you live in Australia?
