Page 1 of 2
clutch for a quick motor
Posted: Mon Feb 27, 2012 6:28 pm
by james lancaster
slowly building up a 200 motor for my road lammy currently got a 200 rapido barrel and mb race tour crank what clutch does every one recommend as theres so many out there the barrel will be worked on by the man him self chalkie white so need something that can stand some hammer
Re: clutch for a quick motor
Posted: Mon Feb 27, 2012 6:49 pm
by RICSPEED
aprilia .. ;)
Posted: Mon Feb 27, 2012 6:52 pm
by james lancaster
link rich ?
Posted: Mon Feb 27, 2012 7:11 pm
by RICSPEED
either look up rocho on here or go here - http://www.granturismo.pwp.blueyonder.co.uk/ or look up rich t on here also .. all depends if you mind having a packer or not
Posted: Mon Feb 27, 2012 7:13 pm
by Oldgit Dave
james lancaster wrote:slowly building up a 200 motor for my road lammy currently got a 200 rapido barrel and mb race tour crank what clutch does every one recommend as theres so many out there the barrel will be worked on by the man him self chalkie white so need something that can stand some hammer
47 tooth version when AF get them in stock
http://www.afrayspeed.co.uk/index.php?p ... buteID=CLU
Posted: Mon Feb 27, 2012 8:33 pm
by mark
Rocho 5 plate will handle any power your engine puts in to with no packer needed just use 10/30 oil
http://scooterotica.org/forum/search.ph ... mit=Search
Posted: Mon Feb 27, 2012 10:49 pm
by james lancaster
HOW MUCH ARE THE ROCHO ONES ?
Posted: Mon Feb 27, 2012 11:19 pm
by mark
pm him on here
Posted: Mon Feb 27, 2012 11:56 pm
by Lamaddict
In the old days (80's) everyone seemed to be able to get away with SIL clutches and extra springs. I went through a period of amazement that people had clutches burning out eventough I was still happy with standard set ups anyway I started reading about them, measuring steels, 5 plates etc and I never had anything buy bother! I'm going for a Saigon Scooter Center one.
Posted: Tue Feb 28, 2012 12:05 am
by Muttley McLadd
What's the gearbox?
If you run a big front sprocket, you'll probably get away with using a four plate with stronger springs.
