loose engine mounts
Posted: Tue Feb 21, 2012 1:46 pm
by fred
I've got an engine casing,but the mounts can be pushed in by hand.Has anyone had this before? will loctite hold it?
cheers,fred
Re: loose engine mounts
Posted: Tue Feb 21, 2012 2:32 pm
by rosscla
fred wrote:I've got an engine casing,but the mounts can be pushed in by hand.Has anyone had this before? will loctite hold it?
cheers,fred
if it still needs quite a bit of pressure to push in by hand then bearing fit might do it ...might be worth looking at chromed mounts or similar as the coating might be enough to make them a bit tighter?
Posted: Tue Feb 21, 2012 4:39 pm
by fred
swapped the mounts from one side to the other,and they weren't hand tight. very strange.
genuine sil mounts. may well just try bearing fit.
fred
