Page 1 of 2
dr 180 jetting problems
Posted: Sat Feb 18, 2012 3:08 pm
by james lancaster
hi all can anyone help me my dads scooters a px125 with a dr 180 kit sterling pipe and 28mm dellorto carb anyone got the jets i need as ive played around and carnt get it to run right
Re: dr 180 jetting problems
Posted: Sat Feb 18, 2012 3:32 pm
by giankx
what carb?
Posted: Sat Feb 18, 2012 3:34 pm
by james lancaster
28mm dellorto mate
Posted: Sat Feb 18, 2012 4:43 pm
by col68
hi mate in my 28mm delly on my tuned 166 I have got a 125 main x2 av264 any help . I had a dr 180 before my 166 couldnt stop head leaking and nipping up on long runs !!! col
Posted: Sat Feb 18, 2012 4:49 pm
by Diablo
Not really surprised you've got problems the carb is way too big
Posted: Sat Feb 18, 2012 5:07 pm
by james lancaster
what we feeling a 26 dellorto ?
Posted: Sat Feb 18, 2012 5:19 pm
by Diablo
If you have one it will certainly work better but still big for the kit.
Posted: Sat Feb 18, 2012 5:23 pm
by james lancaster
what do you think is best ?
Posted: Sat Feb 18, 2012 5:33 pm
by Diablo
To be fair it will run best with a std type carb a 24mm or even a 20mm.
People don't realise just how well std vespa carbs work. If you can get 20hp from a 210 with a std carb why go big on a DR?
If you really have to use a bigger carb I would have thought av264 and start with an X7 needle. Main jet wise I would imagine start with a 115 and work down.
Posted: Sat Feb 18, 2012 7:00 pm
by col68
Not really surprised you've got problems the carb is way too big . That was with standard px125 carb !!! changed to 24 mm then 28 when 166 fitted and dynoed on both !!!
