4stroke carb on a 2stroke
Posted: Thu Feb 16, 2012 1:23 am
by Ivan_200
I have a dellorto phf 32, googled it and it comes on 4 stroke engines (i think). Would it work on a 2 stroke tuned vespa engine? Does anyone have first hand experience on this matter? Thnx
Re: 4stroke carb on a 2stroke
Posted: Thu Feb 16, 2012 11:16 am
by DaveTomo
don't know if this will help,but you can get a bush to convert a 4 stroke PHBH to 2 stroke
http://lambretta.co.uk/catalog/product_ ... ts_id=3486 maybe the same exists for PHF32? or that one may even fit,I don't know.Could be worth contacting eurocarb
http://www.dellorto.com/default.asp but I'm sure I've read somewhere of people using 4 stroke carbs on a 2 stroke, I think Knowledge(Martin) wrote somewhere about aprillia being 2 stroke engines but with 4 stroke carbs.Don't know if any of my ramblings have helped or not.............. I'll get me coat
Posted: Thu Feb 16, 2012 3:01 pm
by Ivan_200
thanx for that info man
anyone else?
Posted: Thu Feb 23, 2012 10:29 pm
by Ivan_200
here's the mail i got
Hi
It could work with 2 strokes if you take the accelerator pump off.
Best regards
Matt Cooper
eurocarb ltd.
Posted: Sat Feb 25, 2012 12:29 am
by Knowledge
I've converted a few 4 stroke carbs to 2 stroke, but if the carb has an accelarator pump, then it sounds like really hard graft to convert it to 2 stroke.
I would put it on ebay and buy something more appropriate.
Posted: Sat Feb 25, 2012 3:23 pm
by Ivan_200
Knowledge wrote:I've converted a few 4 stroke carbs to 2 stroke, but if the carb has an accelarator pump, then it sounds like really hard graft to convert it to 2 stroke.
How did you convert them? So it can't work even with accel. pump on 2stroke?
Posted: Sun Feb 26, 2012 11:19 pm
by Knowledge
Conversion involves pushing out the brass insert that holds the atomiser, and replace it with new brass bush that has a collar which weakens the fuelling at low revs. The bush costs less than a tenner, and it is easy to fit, but my concern is that the original 4-stroke carb might be worth more than a you could buy a second hand two stroke carb.
It seems a risk to try and convert the 4 stroke, fail, and be left with nothing.
With a good description on ebay, it might go well with so many single cylinder 4-stroke trails bikes around these days.....
