Page 1 of 2
the appliance of science...
Posted: Mon Feb 13, 2012 6:43 pm
by goldeneye
picked up an old PX125 motor for bits (f@@ked engine casing , but loadsa good spares on it) and noticed the flywheel is made by Zanussi! it has a small ducati stamp on it , but ive never noticed a zanussi flywheel before.
Re: the appliance of science...
Posted: Mon Feb 13, 2012 6:45 pm
by soulsurfer
Is it written on the plastic fan by any chance?
Posted: Mon Feb 13, 2012 6:47 pm
by red
goldeneye wrote:picked up an old PX125 motor for bits (f@@ked engine casing , but loadsa good spares on it) and noticed the flywheel is made by Zanussi! it has a small ducati stamp on it , but ive never noticed a zanussi flywheel before.
I remember seeing these years ago when riders mainly racers would machine the fins down and then attach the plastic fins from a washing machine.
Posted: Mon Feb 13, 2012 6:51 pm
by gavi4t
i got a letter from zanussi once jeff that had a small stamp on it too ,with the queens head on it :bigsm: :bigsm:
Posted: Mon Feb 13, 2012 8:51 pm
by goldeneye
no no no you daftys! i s**t you not, its an old heavy PX electronic flywheel, unmachined , from a bog standard px, original fins , the lot. never been messed with, not a made up one with a washing machine fan on. its stamped on the actual flywheel. beam me up ......
Posted: Tue Feb 14, 2012 9:10 pm
by gaz_powell
jeff
your not mad - i had one it came on the mk 1.5 px125e i have - it was skimmed so the markings are lost - it was the one that give years of use but sadly cracked in two last year.
it was a heavy type with a window and rubber bung.
CDi was also marked ducati and zanussi
If my italian industrial history serves my right the Ducati brothers established the DUCATI company in 1926; 22 years later, DUCATI was split in two other companies, DUCATI Elettrotecnica and DUCATI Meccanica (today DUCATI Motor).
In 1985 DUCATI Elettrotecnica and Zanussi Elettromeccanica merged to form DUCATI Energia - so around that time the ducati and zanussi name appeared on products
all the best
gaz
Posted: Tue Feb 14, 2012 9:11 pm
by gaz_powell
jeff
all the best
gaz
Posted: Tue Feb 14, 2012 10:15 pm
by goldeneye
it has "83" and 2 dots in the date circle thing, so guessing it"s february 1983 as the time of maufacture, which puts it around the time of the "mk1 and a half" PX"s. ive probably had one before , just never noticed . it has the "rubber bung" hole cast over. the one i run on my px180 is a points ignition one , that has the overlapping magnets from an electronic flywheel! they probably just used what they could get at the time.
Posted: Fri Feb 24, 2012 7:16 pm
by goldeneye
looking at some other bits on this motor, the electronic coil is made by "Plessey". its the original coil, rusted screws holding it to the original bracket. whats even wierd-er, is there was a Plesseys electronic factory in Sunderland!
Posted: Fri Feb 24, 2012 7:34 pm
by bsso78
Thats nowt ive got a stator plate made by Morphy Richards
