Mugello 225 Port Timings
Posted: Sun Feb 12, 2012 1:30 pm
Hi all,
Helping a mate to try improve a Mugello 225 engine, though I'm a bit out of touch with things, so need some help from you guys!
I think the 225 barrel and head are one of the early versions, with 4 small dowels used to locate the head, and with the spark plug precariously close to the frame!
Anyway, I've done a few searches on here and other forums, and it appears these kits didn't/don't perform too well out of the box, and this ties in with when I recently rode it, with it feeling quite flat (for want of a better description).
Even though we've stripped the motor, and all appears ok, I haven't got the engine on the bench as yet, to measure the current port timings etc. (if I can remember how to do it??
), but assume they are standard and that no one has as yet got their dremel on the barrel (though I did notice that the base of the cylinder has the number 570 etched into it - is this just a production number?!).
He is currently using a ScootRS/PM copy pipe and a 35mm TMX Mikuni, and there isn't really the funds to change/improve on these at the moment. Though if there was, I'd probably be trying to persuade him to go for a JL4 race pipe, which I seem to remember worked really well on piston port motors (though is there anything else out there now which is generally recognised as a better power pipe?).
So, initially, we are are just looking at the most cost effective way of improving the engine/kit - mainly to be used for blasting around town and fast dual carriageway riding (not really looking for a touring/rally set up), and therefore looking for some help from our resident experts on here to try and achieve this?!
Fitment of 60 stroke crank would seem to improve the port timings, but then that might be a bit expensive (what's the best budget 60mm crank for this type of motor and cost??).
So, what do you all reckon, get the barrel ported?? And if so, I'd be very interested to know what the desired port timings would be to work best with the ScootRS/PM copy pipe (or the JL4 race, if I can persuade him to stretch to this), because as mentioned previously I really can't remember (from my previous racing days etc.) what numbers we should be looking at??
Finally, as I know he's going to ask me, what sort of bhp/torque output are we likely to achieve from this - hopefully improved - set up??
Thanks in advance,
Tom
Thanks in advance,
Tom
