Dial Gauge - Measuring sprocket heights and run out
Posted: Sat Feb 11, 2012 1:12 am
by rosscla
Anyone got any good pics of the method or a design for a bracket to mount a dial guage for measuing the sprocket heights with a dial gauge?
Also if anyone has pics or ideas for a jig to measure crank run out?
Re: Dial Gauge - Measuring sprocket heights and run out
Posted: Sat Feb 11, 2012 9:43 pm
by wack 63
You could get a piece of ground 13mm square bar from an engineering shop then drill a hole to the gauges outer sleeve size with a tapped thread at 90 degrees to the hole to fit a screw to trap the gauge in the bar.Extensions are available to lengthen the gauges plunger to reach the sprockets. As for the crank truer I have one of these
http://www.scooter-center.com/scoweb/pa ... egory2=CAT ,although a set of Vee blocks mounted on platforms will do.
Posted: Sat Feb 11, 2012 11:26 pm
by DaveTomo
Posted: Sun Feb 12, 2012 12:44 am
by rosscla
Great thanks guys
