water in my exhaust
Posted: Fri Feb 10, 2012 3:29 pm
by crooky
Any reason why id get water in my exhaust took it off to change gearin on my series 2 and there was quite a bit in as in a good glass full. Use it everyday so no problems running its a af clubman. Im begining suspect my daugther and her mate
Re: water in my exhaust
Posted: Fri Feb 10, 2012 3:46 pm
by rosscla
water is a by product of combustion and mostly why exhausts rot from the inside out...a glassfull does seem excessive tho'
Posted: Fri Feb 10, 2012 3:54 pm
by crooky
thanks for that like you say you expect a few drops etc but this was a lot
Posted: Fri Feb 10, 2012 7:12 pm
by richie
Hi there,
Also modern fuel which contains Ethanol is more prone to contain water as Ethanol is hydroscopic. This maybe a reason for more water to appear in the fuel system and exhaust than usual?
I tend to stick to regular fuels which contain less Ethanol than "high" octane products and add octane booster and use quality two stroke oil that is methanol/ethanol compatable.
Saying all that, water vapour will naturally condense in an exhaust as it cools
Cheers
Ian
Posted: Fri Feb 10, 2012 10:56 pm
by storkfoot
Eurolambretta last year. Just leaving for ferry. Got to petrol station on outskirts of Killarney but running was really bad - spluttery and having to keep revs high to keep going. Filled up and then wouldn't start.
After checking the usual, I noticed water seeping out of the expansion chamber. Then I remembered..................
I'd had a half full bottle of water sat on my my runners over the weekend. When I came to pack up it was empty. The previous evening there had been a couple of kids sat by our scoots.................
I think your first instinct may be right
Posted: Sat Feb 11, 2012 6:11 pm
by Beanhead
is that 'OUR' Crooky????
Posted: Sun Feb 12, 2012 3:47 pm
by crooky
ye mate little uns mate has had th'osepipe down it the little **** :biggrin:
Hows the sprinter goin pal?
Posted: Sun Feb 12, 2012 5:10 pm
by Beanhead
hahahaha, slowly mate, off to petes on weds, pick the heads up, then start to build the thing!
the frame to mount the seat is done now, just a few more mock up bits to do then it goes for paint!
cant wait to get it done tho mate, need to run the engine in in the gp, wonder wot 10,000 revs will be like on the lancs??? hahahaha
Posted: Sun Feb 12, 2012 5:56 pm
by warts
IIRC one gallon of petrol when burnt will produce 15 gallons of water. If you have been pootling about in the recent cold snap, then its possible the vapour produced has condensed in your pipe rather than being blown out as per usual.
