Has anyone done this,for their racer or sprinter? I would like to know how to do it.I ve been told you need a lambretta pionts flywheel centre.Is there a lot of machining involved.
Re: Lambretta px flywheel mod
Posted: Fri Feb 10, 2012 1:07 pm
by englishman
yes use a points flywheel boss, as the points boss has the keyway in a different position to the electronic ign boss in relation to the rivet holes ,then it will time up
Posted: Fri Feb 10, 2012 2:30 pm
by rosscla
Here's one already done for you -
Posted: Fri Feb 10, 2012 5:22 pm
by jonny snatchsniffer
i wouldnt put a px flywheel on a lammy there not really suitable for lightening or f@@k all else for that matter, i would however swap the lammy boss onto a pk flywheel, get it machined to 1.2-1.5kg, even a hp4 flywheel if its a genuine one, tho if your revving 9500+ it might s**t the fan off alot
are you doing this cos you got a lot of vespa ignitions or what ?
Posted: Fri Feb 10, 2012 9:36 pm
by jonno
No sniffer its just a racing mod ive been shown,very light includes removing coils apart from ignition one.
