Machining a flywheel
- Doom Patrol
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
How do you turn down the fins on an electronic flywheel? Is it just a question of putting it on a lathe?
WINTERMODEL150
- Main scooter: lambretta ld auto
I cut the end off an old crankshaft bolted it to the flywheel and give it to my machinist who then turned it down.Doom Patrol wrote:How do you turn down the fins on an electronic flywheel? Is it just a question of putting it on a lathe?
Dean
- Doom Patrol
Do you mean layshaft? That was what occurred to me as being one possible way of doing it. It's a SIL flywheel and they are supposed to be turned down to the correct height. But for some reason this particular one looks like it could do with losing another couple of millimetres off it.
- Main scooter: Lambretta
I think he means crankshaft as that's what the flywheel mounts on which would then be able to gripped in a lathe.
Wouldn't it be easier to get the longer indian cowl ?
Don't longer fans move more air? There are some issues about shortening the fins and the gap between the fins and the cowl shouldn't be too big.
- Doom Patrol
Crankshaft of course. My apologies wintermodel. I can't believe I said layshaft. I'm getting my shafts mixed up. I am using an extended cowl as it is and it clears the blades of the fan nicely. A bit too nicely. It's actually too deep and vibrates against the foot board. As it's only a matter of millimetres that prevents it being used with a standard cowl I did wonder if turning the blades down might be a viable option.
WINTERMODEL150
Just bent the foot board down out of the way .Doom Patrol wrote:Crankshaft of course. My apologies wintermodel. I can't believe I said layshaft. I'm getting my shafts mixed up. I am using an extended cowl as it is and it clears the blades of the fan nicely. A bit too nicely. It's actually too deep and vibrates against the foot board. As it's only a matter of millimetres that prevents it being used with a standard cowl I did wonder if turning the blades down might be a viable option.
Dean
- corrado
- Dealer
- Main scooter: Lambretta GP
[quote="Doom Patrol" I am using an extended cowl as it is and it clears the blades of the fan nicely. [/quote]
You don't want "nicely" clearance, you want it as close as possible without touching the fan for the best cooling effect.
easier to mod cowling by just elongating screw holes tbh and its more adjustable that way
OzOAP
- Main scooter: Vespa PTS1E
Was told by 'an expert' (there are a lot about), that the tall fin ones dont flow anymore air than short ones, coz of the air gap between them.
I use to leave fins 'indian' height but remove everyother one.
- Doom Patrol
You don't want "nicely" clearance, you want it as close as possible without touching the fan for the best cooling effect.[/quote]corrado wrote:I am using an extended cowl as it is and it clears the blades of the fan nicely.
I know. I'm aware of that and that's the real reason I want to get it done. Although, in all fairness it doesn't appear to have had any detrimental effect. But, as the cowl is rubbing on the footboard it's the perfect excuse. Odd though. It's a SR flywheel and turned down to the correct height. but plainly still a tad too tall.
