Crank replacement
Posted: Sun Feb 05, 2012 5:55 pm
by marburys
Hi need some help on this one , i'm gonna strip my tv engine as driveside seal as gone , i want to put a gp crank (stronger i been told than Li crank ) in how do i go about making sure i get the right one - or how do you measure them to get the right one ,cheers marc
Re: Crank replacement
Posted: Sun Feb 05, 2012 6:48 pm
by WINTERMODEL150
marburys wrote:Hi need some help on this one , i'm gonna strip my tv engine as driveside seal as gone , i want to put a gp crank (stronger i been told than Li crank ) in how do i go about making sure i get the right one - or how do you measure them to get the right one ,cheers marc
Hi marc,the gp crank has a longer and fatter taper on the flywheel end ,you will need to get an nu2205 bearing as well for the mag housing and when fitting this bearing you will need to leave the top shim out as the bearings deaper also you will need to change the flywheel as the gp crank will be too big on the taper.
In my experience if your engines standard I'd stick with what you have if the cranks ok ,you very rarely hear an li/tv magside bearing wearing out due to the short taper on the crank ,hope this helps.
Dean
Posted: Sun Feb 05, 2012 6:56 pm
by marburys
Cheers Dean i just replace all bearings and seals thanks marc
Posted: Sun Feb 05, 2012 6:59 pm
by WINTERMODEL150
marburys wrote:Cheers Dean i just replace all bearings and seals thanks marc
Get A MEC crank you cant go wrong seem reliable.
Dean
Posted: Mon Feb 06, 2012 12:23 am
by corrado
If it's a genuine TV crank then you'd need to get a replacement crank with a 116 rod to match your TV piston. MEC and other companies do them but I'd imagine that they have the GP200 taper and would need GP flywhhel and magside bearing to match.
If you're not tuning the engine I'd leave it as it is.
Posted: Mon Feb 06, 2012 5:44 pm
by marburys
Cheers Martin i'm not tuning it so i will just replace bearing and seals. Thanks Marc
