Page 1 of 2
ts1 230 gearing
Posted: Sat Feb 04, 2012 8:18 pm
by golf19gt
i have a ts1 230 with 34mm carb jl3 exhaust it has a pacemaker box with 16x47 can it handle going to a 18 front sprocket and will it pull this gearing ok
Re: ts1 230 gearing
Posted: Sat Feb 04, 2012 8:52 pm
by fred
should pull 18/47 no probs
fred
Re: ts1 230 gearing
Posted: Sat Feb 04, 2012 8:59 pm
by phil23fair
If you look at your last query on this topic you'll see that both me and Soulsurfer think this will be OK
Re: ts1 230 gearing
Posted: Sat Feb 04, 2012 10:15 pm
by golf19gt
spoke to mb developments and they said if i go to 18 i would have to puy a jl4 race pipe on to pull it
Re: ts1 230 gearing
Posted: Sun Feb 05, 2012 4:58 am
by RICSPEED
doesnt sound right to me !!
Re: ts1 230 gearing
Posted: Sun Feb 05, 2012 11:55 am
by phil23fair
If you're unsure then the easiest thing to do is fit a 17 tooth front sprocket - you must have an 81 link chain with the gearing you're running now and it's probably worn enough. This is going to cost you about £25, less if you put a wanted add up on here and somebodies got one to sell.
If it still pulls really well with 47/17 then you can consider buying an 82 link chain and 18 tooth sprocket or leaving it as it is.
Re: ts1 230 gearing
Posted: Tue Feb 07, 2012 9:37 pm
by jimmo
I run a 16/46 on mine - Li150 box.
TMX35 carb and Franspeed Race pipe.
Pulls like a steam train when in the power kicks in at 5000 rpm!
Re: ts1 230 gearing
Posted: Wed Feb 08, 2012 9:49 am
by phil23fair
jimmo wrote:I run a 16/46 on mine - Li150 box.
The closest you'll get to Jimmo's gearing is 47/18 with your pacemaker box. His will be doing 10.5 mph/1000rpm in 4th, yours 10.6mph/1000rpm.
Re: ts1 230 gearing
Posted: Wed Feb 08, 2012 7:06 pm
by golf19gt
ok thanks started putting in 18 front also found out today the exhaust is a jl4
Re: ts1 230 gearing
Posted: Wed Feb 08, 2012 8:26 pm
by GP240
Had a JL4 (until it split) on a TS1-225, cant remember what sprockets but had Li150 box and gave 4.6 final ratio. took a bit to get up to revs but when it did it pulled like a good un. will find you have to drop into 3rd if the revs die off. great fun tho.
