Fitting new fuel tap in PX tank
Posted: Sat Feb 04, 2012 4:31 pm
just about to fit a SIP fast fuel tap on a PX.
The haynes manual (page 65) states that you need a special tool part number Too32973 in order to complete the task.It looks like a T bar at the top with a long metal pipe with a spanner end at the bottom of it.
Is the nut held and the tap turned or the tap held on the outside with the nut tightended from inside??
Is there another simple way to holding the nut from inside the tank without buying the special tool?????
Cheers
Phil
Cheers
Phil
