Page 1 of 3
Barn Find Vespa
Posted: Sun Jan 22, 2012 3:30 pm
by wax
Re: Barn Find Vespa
Posted: Sun Jan 22, 2012 3:42 pm
by Bofs
Looks like a Vespa Douglas 152L2 circa 1960, unfortunately that was the chassis number that was on the alloy plate
but you still have the reg on the tax disc so maybe through the right channels you could recover the log book
Re: Barn Find Vespa
Posted: Sun Jan 22, 2012 4:15 pm
by Juan
Douglas chassis and engine numbers were the same so if it's the origonal motor then that'll get you the frame number.
Re: Barn Find Vespa
Posted: Sun Jan 22, 2012 5:06 pm
by wax
Does that mean i could make a new VIN plate for it?
Re: Barn Find Vespa
Posted: Sun Jan 22, 2012 5:55 pm
by Doom Patrol
wax wrote:Does that mean i could make a new VIN plate for it?
Shhhh...... I didn't hear that, right?
Re: Barn Find Vespa
Posted: Sun Jan 22, 2012 5:59 pm
by wax
Also, as i am warming to the idea of owning a vintage vespa. How much work is involved in putting a P200 engine in and disc brake forks?
Re: Barn Find Vespa
Posted: Sun Jan 22, 2012 6:22 pm
by soullad
wax wrote:Also, as i am warming to the idea of owning a vintage vespa. How much work is involved in putting a P200 engine in and disc brake forks?
Engine relatively simple, thou you'll need to check the rear shock height, and possibly cut a piece out from the inner section to allow the room for movement under normal suspension travel, with the standard p2 carb body often the part that catches.
As for the forks, I think SIP do some great suspension upgrades if you wanna keep it standard looking, if not think about mudguard mounting, steering stop lug and headset pinchbolt location and overall ride height. Often these conversions raise the front end by an inch or so and so the stand needs altering.
Re: Barn Find Vespa
Posted: Sun Jan 22, 2012 6:47 pm
by wax
Do the SIP conversions make use of the standard forks then? Can i use a disc brake with these?
Re: Barn Find Vespa
Posted: Sun Jan 22, 2012 8:09 pm
by Juan
No reason why you couldn't make your own VIN plate, they were just a plain alloy tab rivetted to the frame and no other information on it. I'd hardly class that as forgery.
P range motors etc pretty much a bolt in with the carb box maybe being the only issue as mentioned. Front end would depend on how authentic you want things to look. Worb5 do a disc set up to suit Rally etc. forks but it's big bucks and if you're not worried about the old style forks then using a PK fork is a much better idea altogether.
Re: Barn Find Vespa
Posted: Sun Jan 22, 2012 8:35 pm
by Bofs
As mentioned. PX engine goes straight in, PK forks too ( I had to weld in 2 lugs for a steering stop). 152L2`s don`t have a steering lock so no worries there.
