Octagonal headset issue
Posted: Fri Jan 20, 2012 11:00 pm
by 20QL
Does anybody know if an octagonal sx type headset(non chrome ring type) would fit on a Li125 chrome ring frame? Would this depend on the type of forks i have?
cheers
Re: Octagonal headset issue
Posted: Fri Jan 20, 2012 11:11 pm
by RICSPEED
no ...unless you remove the chrome ring as the non ring headsets are longer at the bottom to take up the space where the ring was
Posted: Fri Jan 20, 2012 11:28 pm
by 20QL
Is it just as simple as that? ie remove the chrome ring and fit the non chrome ring bearing assembly and then the headset will fit?
Cheers
Posted: Sat Jan 21, 2012 9:59 am
by badal1965
You will have to change the top steering bearing cone as well and unless you make up and weld on a bracket you will lose your steering lock as well. :)
