Just got a fibreglass seat for the sprinter but interested to hear how others may have fitted theirs.
My Initial thought was to put a steel reinforcing plate underneath seat running down its length and drill 4 holes for countersunk hexhead bolts resting on a number of nylon washers to protect the body.
Unless you have a better thought out way of mounting.
Cheers.
North Liverpool Academy
Re: Fibreglass race seat
Posted: Thu Jan 19, 2012 7:29 pm
by RICSPEED
would be help full to post some pics of the seat and what you want to fix it to ..is it standard loop etc ??
Posted: Fri Jan 20, 2012 12:13 am
by storkfoot
Eibar, I can't speak from experience yet but I'll be doing this too in a few weeks. I was going to use 4 socket head flange button screws, maybe with repair washers to spread the load on the fibreglass, and nylon washers between the seat and the frame. I'll be putting a 2.5mm racing foam on top as a seat.
I was working on the basis that the fibreglass would be strong enough to cope with my ample weight without any further metal plate but I can see where you're coming from.
Posted: Fri Jan 20, 2012 11:52 am
by mark
I love the word flange it's nearly as good as gusset and neither are used enough
Posted: Fri Jan 20, 2012 8:31 pm
by gaz_powell
hi
i`ve just done one :-
1. Cut two plates about 125mm square out of 1mm mild steel and drilled a 9mm hole in each corner matching the four holes in the frame behind the petrol tank hole - the mounting position
one plate for the top and one for the bottom (plate/seat/plate) to stop the fibreglass been damaged when finished and bolted up and for the fixing bolts - see item 3 below
2. Ground the heads down on four m8 bolts which where long enough to go through seat and frame to bolt up - ground them down so i could keep the padding as thin as possible and the bolts would nt be felt on my boney arse.
3. Put the bolts throught the plates/seat/plate and a nut on the underside - once it was all lined up on the frame it was nipped up and the bolts welded to the top plate
4. Remove the nuts and replace them with a hard rubber washer to protect the frame/paint
5. painted the plates then covered it
hey presto finished - now i just need a new rack
hope all that makes sense without photos
best of luck
gaz
Posted: Sat Jan 21, 2012 11:54 am
by Eibar
Thanks for the answers people, metal plates have been cut and I think I'll go with the buttonheads option topped off with some high density foam.
Posted: Sun Jan 22, 2012 12:43 pm
by Beanhead
i take it your using the standard loop? mines going to be fitted to two bars extending up from the frame ( no loop ),going to have several holes for fitment to get the seating right so it can be adjusted as nec, i'm using the old TZ type (cheers Ricspeed ), i will put a small square plate undrneath to spread the load.
