GP wiring
Jeff T
Main scooter: GP150 & LI150 S2
Putting back together after some paint work, I've wired everything up but I've a red wire, not the head light one but from the main harness that I am not sure where it goes (early Indian GP150 no battery) I've looked at the wiring diagram in Sticky's but can't fathom. Any ideas?
Jeff
It's not at the headlight end?
roughly where in the loom is it in relation to the scoot?,half way, rear etc.
Does it come off the loom with any other wires, if so what colour are they?
Is it a new loom?
Does it have terminal on it?, is it round? (the terminal not the wire).
Was it one you took off for the respray?
Rich
Jeff T
Hi it's in the headset and it comes out of the loom with all the main wires, its the original loom and there are two wires taped up that I am pretty certain where for the kill switch, I've had the headset off loads of times but can't remember the red wire not being connected, it didn't have any connector on,
When I took the headset off I took some photo's although they are not that clear it looks like the red wire wasn't connected, now the only issue I had before was the main beam/dip didn't work but I think that was because there was a problem with the soldering/wiring on the handle bar switch which I have repaired.
    Users browsing this forum: Amazon [Bot] and 5 guests
