Changing exhausts - what else needs changing?
Posted: Wed Jan 18, 2012 4:32 pm
by amc
Hi,
Currently running a muggy 186 with 30mil PHBH, Ram Air filter and AF Clubman on an LI150 box with 16/46.
Changing exhaust to under kickstart fresco. So questions are:
1) Do I need to go back to 15/46
2) any suggestions for starting point on jetting?
Alex
Re: Changing exhausts - what else needs changing?
Posted: Wed Jan 18, 2012 5:54 pm
by ArmandTanzarian
amc wrote: Changing exhaust to under kickstart fresco.
Why? Do you like falling off every time you turn right? The ground clearance is terrible.
Posted: Wed Jan 18, 2012 10:00 pm
by amc
It does look less clearance than the clubman, but i thought i would give it a whirl. Always fancied one.
Any ideas on gearing and jet change? Its a bit revvier so assumed the 16 tooth front sprocket might be a bit much.
