Bit of a bodgers question I know but I've used silcone in the joints but still leaks and end up with black shite everywhere, anyone ever tried using heatshrink around the joints and will the heat of the exhaust cause a problem, I have got some that will fit and the spec is 110 degrees but not sure if it will cause a problem. Any ideas ?
look on ebay there are rubber sleeves that you can lock wire or jubilee clip on, i wouldny use exhaust past as it can be perminant and ruin the exhaust
What about at the stub? Any gud suggestions what to use there my franspeed is leaking like a gudn! nice black sh1t dribbling out of there. Ive got the rubber as above works a treat.
Re: Slip joints
Posted: Sun Jan 15, 2012 11:38 am
by mark
Too much oil in your mix
Slip joints
Posted: Sun Jan 15, 2012 2:43 pm
by jonashford
Cud be gotta refuel soon so I'll remix fuel
Re: Slip joints
Posted: Sun Jan 15, 2012 7:35 pm
by cezeta
wurth do a hi temp matt black silicone sealant. its gggggreat.
it wil seal a slip joint or anything else you need sealing. if you spray the surfaces with brake cleaner first then it sticks like crazy.
i have re built engine mounts with this stiff and twigs before and it lasted from italy to the uk. also sealed a split petrol tank which lasted 500 miles or so.
Re: Slip joints
Posted: Sun Jan 15, 2012 8:17 pm
by jonashford
cezeta wrote:wurth do a hi temp matt black silicone sealant. its gggggreat.
Any idea what its called?
this came up on fleabay
only goes to 250 degrees tho,
