Oil seal gone !
Posted: Sat Jan 14, 2012 10:28 am
by flipster
Hello All,
Pulled off my rear hub today to find that brake shoes blatted in oily crap !
Final drive oil seal shot.So thats why I had trouble stopping !
So is it possible to replace the seal without major strip down ? (i.e. from hub side )
Please excuse my lack of mechanical know how but Im trying
Cheers in advance to all you spanner wielding whizz kids out there.
Re: Oil seal gone !
Posted: Sat Jan 14, 2012 11:39 am
by mark
ease as pie tbh , if it continues leaking tho its prob the o ring onthe layshaft which is a total gearbox strip
Re: Oil seal gone !
Posted: Sat Jan 14, 2012 8:37 pm
by flipster
Thanks for the replies Eden, Mark. Hopefully it will be a simple job.
Otherwise I can see a trip to Ripon on cards
You busy Sean ?
Re: Oil seal gone !
Posted: Sat Jan 14, 2012 11:21 pm
by Toddy
Also check between the bearing and the casing I've known certain bearings spinning in the crank case causing oil leaks
Re: Oil seal gone !
Posted: Sun Jan 15, 2012 11:56 am
by Supereibar
Toddy wrote:Also check between the bearing and the casing I've known certain bearings spinning in the crank case causing oil leaks
Must be newly fitted bearings. The only bearings I know that fit in every single Li motor are RIV bearings. Whatever the public opinion is on them. They DO fit.
Re: Oil seal gone !
Posted: Sun Jan 15, 2012 12:01 pm
by Toddy
Supereibar wrote:Toddy wrote:Also check between the bearing and the casing I've known certain bearings spinning in the crank case causing oil leaks
Both indian origin bearings don't know how long fitted when I found
