Dellorto 28mm Jetting
Posted: Fri Jan 13, 2012 7:44 pm
Running an MB SIL RT 210 set up. 25mm Dellorto with foam filter, 42mm KBA and GP200 Indian box 46X19. It's going well but get the feeling that the engine could pull more with a bigger carb on so I've got a 28mm Dellorto to go on and looking through different setting others have I've gone for - 120 Main, 50 pilot, AV264, X13 Needle, 2nd clip down. Any comments on this before I bolt it on?
