vespa engine vnt1
Posted: Thu Jan 12, 2012 1:36 pm
by dobaroono1
i have a 1963 vespa,i think its either a vbb or vba but not certain,the engine however is a vnt1 which i believe was built for the swiss market,the kickstart is damaged i.e.the teeth are worn and i need to source another one,the teeth on the kickstart go all the way round as opposed to half or 3/4 as on other models i've had,i have tried looking on european vespa forums to get more info and the elusive kickstart but i only speak english,can anyone help me?thanks in advance neil
Re: vespa engine vnt1
Posted: Thu Jan 12, 2012 2:55 pm
by jonny snatchsniffer
the vnt is a 125gt 1961-1962 with 10 inch wheels if that helps
Posted: Thu Jan 12, 2012 3:02 pm
by dobaroono1
the engine has 8" wheel and the kickstart i need is with the tread on the end moulded in and you dont need a pedal rubber,similar to a small frame kickstart,i got some info on the net that some parts of the vnt1 engine are the same as vbb and vbb,this is the first time i've seen a kickstart with the teeth all the way round,wonder if anyone can tell me what the kickstart on the gt125 looks like
Posted: Thu Jan 12, 2012 4:01 pm
by dobaroono1
the exact model of the vespa is vba 1964
Posted: Thu Jan 12, 2012 5:46 pm
by dobaroono1
the engine number on the scooter is vnt1m,a 125cc engine originally in a vnt1t chassis this scooter was aimed at the swiss market..motoradd,can anyone help me find a kickstart for this model?
Posted: Thu Jan 12, 2012 5:54 pm
by hobospeed
Sounds like you need a fully spline'd kick start quadrant which were common on most VNA and early VNB motors. It shouldn't be that hard to track one down a used one as it's pretty common for people to switch it out for the later style 1/4 spline'd type that aren't know for stripping as easily as the version you are looking for. I'm pretty sure I have one or too in storage but the shipping for Canada isn't worth it.
Good luck,
Tim
Posted: Thu Jan 12, 2012 6:01 pm
by dobaroono1
hello tim,the quadrant thats on the scooter must be a fully splined on to match the kickstart,you reckon if i can locate a quadrant from a vbb or vnb and a kickstart to match that would fit into my engine?i will then have to get an engine gasket?
Posted: Thu Jan 12, 2012 6:48 pm
by hobospeed
dobaroono1 wrote:hello tim,the quadrant thats on the scooter must be a fully splined on to match the kickstart,you reckon if i can locate a quadrant from a vbb or vnb and a kickstart to match that would fit into my engine?i will then have to get an engine gasket?
Yes a VBB/Sprint quadrant will fit into the engine no problem.
Here is one that will fit your current quadrant, but it has the later style kick area:
http://www.sip-scootershop.com/en/produ ... a_15001500
Posted: Thu Jan 12, 2012 7:36 pm
by dobaroono1
thanks tim i think i have a 150 super quadrant and kickstart so i'll give that a go...neil
