ts225 tmx 35
Posted: Mon Mar 30, 2009 12:07 pm
by martinr
im running a tmx 35 jl3 li150 16/46 but cant get over about 75 mph
jetting is main 320 idel 22.5 and 57 needle second from top clip do you think i can drop to 300/280 main
ps no filter
Re: ts225 tmx 35
Posted: Mon Mar 30, 2009 12:16 pm
by drunkmunkey6969
id change your exhaust, not your jets.
Re: ts225 tmx 35
Posted: Mon Mar 30, 2009 12:32 pm
by craze01
Until recently I ran the same gearing as you but with a jl4 and found the best main jet was a 290 and even got away with a 280 but up jetted just in case.
The transfers have been matched to the casing and the exhaust port has had a little work on it too!
Are you using gps for your speed check as to be honest if you are a ts1 doesnt really get that much faster in the real world!
I would say 80ish is probs the most you would get out of your set up with a gps reading unless its on your cut down as that has no legsheields as a wind break!
Re: ts225 tmx 35
Posted: Mon Mar 30, 2009 12:39 pm
by camel
im down too a 290 aswell...with a filter
Re: ts225 tmx 35
Posted: Mon Mar 30, 2009 2:19 pm
by martinr
thanks for replys chaps i cant afford a new exhaust times are hard you know
it is on my cutdown its not on gps but one of those vapour digital speedos which are pretty good i think im really doing about 70. my mate has a muggy 225 and can just about keep up on a full frame
and we cant have that
ill try a 300 main
Re: ts225 tmx 35
Posted: Mon Mar 30, 2009 2:21 pm
by drunkmunkey6969
martinr wrote: ill try a 300 main
Carefull with no filter.....
Also....whats plug colur like?
If plug colour is OK, i'd leave it as is.
Re: ts225 tmx 35
Posted: Thu Apr 02, 2009 3:33 pm
by madmaex08
16/46 on LI150 is 7200 rpm for the 75mph. this is about the same as my TS1 revs with the JL3 exhaust. just I´m using 18/47 on the li150 and a koso32 which the engine pulls strong in each gear until the exhaust stops dead at around 7200. but 82mph is absolutely enough for me since i hardly use motorways and even there you are not allowed do go faster (at least in my country). with a little more exhaust timing you could certainly get him to rev further, but with some loss at the bottom of course.
the JL3 makes superb bottom end power, but absolutely refuses to rev high up. this suits a good roadgoing setup with long gearing but is definitely the wrong choice for revving up the scale.
either you change the exhaust, change the gearing if your engine is grunty enough or stay with what you have and save the hassle/money. i personally don´t think main jets will get you anywhere on this.
Re: ts225 tmx 35
Posted: Thu Apr 02, 2009 4:12 pm
by drunkmunkey6969
madmaex08 wrote:.....i personally don´t think main jets will get you anywhere on this.
I agree.....the only place it will get you, is trouble....when you hole a piston.
