Revolver/RZ/JL right hander exhaust runs lean?
ricalnic
Main scooter: Lambretta GP Monza 225
I had one on my 210 malossi originally, extreme pinking at top end no matter what jet. had to back off the ignition to about 15deg (or less :-( )
I had a small leak on mine and changed to a Taffy, still had to run the extreme retarded ignition. ended up junking the Malossi HSTR head an getting a slightly lower comp of 11.5-1 (from malossi 12.5-1) head from SIP,I was then able to put timing back at 18deg and run flat out no problem - off the clock :-) luv it
gaz_powell
yes i had the same problem with a mates bike
On a stock p200 motor following full rebuild - put a 125 main jet in it to run the motor in and - he pottered about town and got some miles on it - so off we went to Cleethorpes after about 45miles at about 55mph it holed the piston. No leaks anywhere when i checked it over. As i said it wasn`t mine and the lad was selling it after cleethorpes so it had a new top end put on and i backed the timing off to and put a 128 in but i never got to try it.
ricalnic
if using the HSTR head, try putting a head gasket on it for a test, thus lowering the compression, longer term however you should look at the correct head with correct squish.
also try retarding the ignition.
don't do both together though, one thing at a time.
when you say running lean, is this witnessed from plug chops ?
fraserp200e
Main scooter: 1988 MotoVespa TX200
gaz_powell wrote:yes i had the same problem with a mates bike
I've been running a 122 jet on my standard p200e with RZ MKII RHS exhaust for over a year with no snags at all (driven every day) when I got the exhaust, the info I got from the manufacturer said it would run up to a 124 jet but to start with a 122 an do regular plug chops to check the colour. Mine has been fine at the 122 so never bothered upping it to 124.
1983 Vespa PX125
1984 MotoVespa P200E
    Users browsing this forum: Ahrefs [Bot] and 2 guests
