px ignition key barrel
Posted: Fri Jan 06, 2012 11:59 pm
by joey
...just stripped the whole scoot down...but i can't get the lock out ? i've took 1x grub allen screw out and tried to drift out but won't budge...give us a clue?
Re: px ignition key barrel
Posted: Sat Jan 07, 2012 8:51 pm
by vesbrettas
i take it your taking about a efl/disc if thats right with the forks out and the grub screw out the pull the b
plastic switch out and then the steering lock both towards the front of the scooter, once they are out you sould see the back of the barrel and there will be a small tap on the side which you push in with a small screwdriver and with the key in the ignition push the centre of the barrrel and it should slide out, then just tap the surround out
