Page 1 of 2
Which dellorto
Posted: Wed Jan 04, 2012 10:40 pm
by Arch_Stanton
Finally got my TS1 kit from A/F today, hope to fit a 30mm dellorto on a LTH manifold,
Would like to know if the VHSH flat slide carb is worth the extra money over the standard PHBH carb?
Re: Which dellorto
Posted: Thu Jan 05, 2012 1:45 am
by GP240
What size Kit with 30mil
Ben told me my 225 shouldn't be run with anything under 34mil open mouth.
I run a 32mil VHSA with foam filter (for now).
What pipe you thinking of using?
Re: Which dellorto
Posted: Thu Jan 05, 2012 2:25 am
by blue
I run a 30 vhsh on my ts 230, exellent carb in my opinion.
Whether or not it's worth the extra money i have no idea.
Re: Which dellorto
Posted: Thu Jan 05, 2012 8:14 am
by Toddy
I originally ran a 34 on my TS but changed last year to the 30 VHSH seems a lot more responsive and before i fitted the filter got less spit back
Re: Which dellorto
Posted: Thu Jan 05, 2012 8:57 am
by Arch_Stanton
Its a standard 225 with a franspeed pipe and SX200 gearing, hoping to run with a filter if anythings suitable.
Re: Which dellorto
Posted: Thu Jan 05, 2012 10:12 am
by Diablo
John talk to Graham Yates. Sorted his last year PHBH with a powerjet.
I'd save the extra money a VHSA costs and spend it on a powerjet.
Re: Which dellorto
Posted: Thu Jan 05, 2012 10:23 pm
by Arch_Stanton
Cheers for the replies.
Think you're right Al, I'll go for the PHBH + powerjet, was just a question of aesthetics, but they both look the same with the panel on
While we're on the subject, are the standard piston (2 ring ASSO) and reeds OK. Is a reed packer still an advantage?
Top end will be a basic standard kit, so how much money do I need to throw at a suitable crank?
Re: Which dellorto
Posted: Thu Jan 05, 2012 11:10 pm
by TS1-200
I reckon on a standard TS1, the reeds & piston are fine, as far as the packer plate goes it all depends on the clearance between the frame and inlet manifold, on my innocent GP for some reason I find it difficult to get a decent (3mm) gap, even with an MB manifold and offset frame cones, so I replaced the 5mm packer with a 3mm packer plate and its fine now, it does seem to vary between scoots though.If you`ve not ridden a TS1 before you will enjoy it.
Re: Which dellorto
Posted: Fri Jan 06, 2012 12:43 am
by joeswoonara
If you`ve not ridden a TS1 before you will enjoy it.[/quote]
oh i think he`s done that before
Re: Which dellorto
Posted: Fri Jan 06, 2012 1:15 am
by Diablo
Haven't had any problems recently with the Asso pistons. There have been issues with ring pegs but I think sorted for some time now.
The std reed set up is actually very good. There is an obstruction to the boost port but unless your going for a tuned motor there must be hundreds running this set up quite happily.
