PX RIGHT REAR INDICATOR NOT WORKING
Posted: Tue Jan 03, 2012 10:58 am
by wink
Hi all, I have just got a 1984 P125xEFL, this bike has been standing outside for over 7 years. I have got the engine going relatively easily and all lights seem fine. All indicators are working except the rear right.
I have carried out the usual tests, Panel earths & bulbs and cleaned up and WD40'd the relevant connections and switches but still not working. It's not the panel as I fitted a working one and still no joy. The indicator light in the speedo is not working (but not sure if this would effect it, poss some earth???). I have now moved to checking and replacing the plunger and spring in the frame that connects to the panel.
Can anyone recommend an easy way to remove the plunger/spring unit from the frame as it's proving somewhat stubborn.
Also any further suggestions or help above would be well received.
Thanks in advance Chris
Re: PX RIGHT REAR INDICATOR NOT WORKING
Posted: Tue Jan 03, 2012 12:42 pm
by squeakmillward
usually smash them off and use a new one ;)
Posted: Tue Jan 03, 2012 1:07 pm
by Craig H
Have you checked the soldered connections on the back of the indicator switch and the wires have not broke inside the sleeving or try diff indicator switch just to eliminate the switch out the problem.
Posted: Tue Jan 03, 2012 6:05 pm
by vesbrettas
the first thing i would test would be to use a test lead or multimeter to see if your getting power to the frame socket and then work from there either forwards or backwards
Posted: Tue Jan 03, 2012 11:11 pm
by ducksta
you say the rear indicator is not working whats wrong with it, does it come on then go off again then on again then off again mmmmmmmmm interesting :anbrgin; :anbrgin;
Posted: Thu Jan 05, 2012 10:15 pm
by wink
Hi all, thanks for the help, I've finally got it sorted, it was a poor panel earth to the frame that was causing the problem. I rubbed back all the rusty connections liberally applied the old wd40 and voila, all is working fine. Cheers again Chris
Oh and Lol ducksta
Posted: Thu Jan 05, 2012 10:35 pm
by ducksta
only having a bit of fun m8 :anbrgin; i had same probs after having a full vespa powder coated what a knightmare
Posted: Sun Jan 08, 2012 3:24 pm
by fraserp200e
wink wrote:Hi all, thanks for the help, I've finally got it sorted, it was a poor panel earth to the frame that was causing the problem. I rubbed back all the rusty connections liberally applied the old wd40 and voila, all is working fine. Cheers again Chris
Oh and Lol ducksta
Just had the same snag with mine - after loads of trial and error and swapping bits, it turned out I had a bad connection at the spring clips, cleaned them off and they're all sorted now
