gps speedo headset
Posted: Mon Jan 02, 2012 9:25 pm
After messing about with different speedo's including koso i got fed up with the unreliabilty of them and farting about with pick-ups and magnets etc, I eventually took the plunge and treated myself to an anolgue gps speedo made by an American company called speedhut.. It came and what a bit of kit.. superb and easy to wire just connect it to 12 volts(dc unfortunately) position the antenna and away you go..proper odometer and trip and lots of other functions inc 0-60 timer, 1/4 mile timer etc etc..
I aquired a cheap head set and got a friend to machine me an ally ring .I then cut a hole in headset then got the ring tigged into the headset
filled and rubbed down
Etched primed , flated down and then filler primed and flated down again
Just got to get it top coated now to match scoot.
The speedo you get from speed hut is made to your own required colours ie face colour, bezel, ,digits and logo if required...
Just waiting to get the green top coat now..
...I aquired a cheap head set and got a friend to machine me an ally ring .I then cut a hole in headset then got the ring tigged into the headset
