Breather plug
Posted: Sun Mar 29, 2009 10:43 am
I have the old problem of my breather plug spitting out oil, no seals are shagged , is there a fix for this?
frank
frank
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Good advice and seconded by me....bristolmod wrote:I always use an original breather plug from which I've removed all the crud and the wire wool from the last 40 odd years- this allows any build up of pressure within the case to exit via the plug as intended and not force its way past any seal. There may be a slight "weeping" of oil but this is preferable to a blown seal IMO
Pretty much what i'm thinking.... but running a hose from the breather plug to the air filter, simular deal to a PCV setup on a car.Avantone wrote:I've seen a few breather bolts machined down to accept a flexible plastic tube with a small air filter on the end.
I'm sure someone was producing them, but would be fairly simple to knock up yourself.
I thought this was only done on a four stroke, somthing to do with crank pressure and Inlet vacume on diffrent parts of 720 degree ( Two revolutions ) four stroke cycle.... I would be very interested to know how this performs if you connect back to the air box. Please dont forget to post back your findings if you go down this route, as any knowledge gained is a good thing....another Idea on this forum that I had never thought of....so for now disregard my last post...red ghost wrote:Pretty much what i'm thinking.... but running a hose from the breather plug to the air filter, simular deal to a PCV setup on a car.Avantone wrote:I've seen a few breather bolts machined down to accept a flexible plastic tube with a small air filter on the end.
The remote breathers I've seen vent to atmosphere, and were not recycled. Though one of the photos on the 100 MPH Lambretta Club site show a breather tube disappearing into the main frame tube, with what maybe an integral filter?J1MS wrote:I thought this was only done on a four stroke, somthing to do with crank pressure and Inlet vacume on diffrent parts of 720 degree ( Two revolutions ) four stroke cycle.... I would be very interested to know how this performs if you connect back to the air box. Please dont forget to post back your findings if you go down this route, as any knowledge gained is a good thing....another Idea on this forum that I had never thought of....so for now disregard my last post...red ghost wrote:Pretty much what i'm thinking.... but running a hose from the breather plug to the air filter, simular deal to a PCV setup on a car.Avantone wrote:I've seen a few breather bolts machined down to accept a flexible plastic tube with a small air filter on the end.
