Carb correction tables
Posted: Fri Dec 23, 2011 4:04 am
Just finished reading the Understanding Carburetion post in Tuning/maintenance http://tinyurl.com/8a25p5h and it mentions using correction tables to adjust jetting for altitude/temperature changes. Is there such a table for dellorto/Spaco SI carbs? If not, will the adjustments be the same percentage as the table in the article?
