Carb correction tables
sailor
Main scooter: 75 Rally 200
Just finished reading the Understanding Carburetion post in Tuning/maintenance http://tinyurl.com/8a25p5h and it mentions using correction tables to adjust jetting for altitude/temperature changes. Is there such a table for dellorto/Spaco SI carbs? If not, will the adjustments be the same percentage as the table in the article?
