Page 1 of 2
PX 125 barrel upgrade
Posted: Tue Dec 20, 2011 3:45 pm
by AndyS
Of all the kits available for the Vespa PX125, which would give the best performance. I am only really looking at the Malossi, Pinasco,Polini, Dr180, or the Parmakit. I dont really want a high revving screamer, more torque and an improved top end.
Am going to use the si24 carb and a sito plus exhaust.
I dont mind porting the casings.
Would the standard crank be up to the incresse in power
Thanks
Re: PX 125 barrel upgrade
Posted: Tue Dec 20, 2011 6:33 pm
by Train Driver
I went with the DR kit as it was given to me by my sponsor cezeta
kept the standard carb but added a sito plus
dyno'd by alan (diablo)
it makes enough power just needs up gearing.
I have now given up on the 80mph all day cruiser its not possible on a vespa or lambretta
Posted: Tue Dec 20, 2011 7:20 pm
by AndyS
How much is that an increase on standard
Posted: Tue Dec 20, 2011 8:13 pm
by Train Driver
Power and torque up by 20% i have been told its making just a little more than a standard 200
Posted: Tue Dec 20, 2011 8:39 pm
by AndyS
is the DR the best of the kits, i understand the Parmakit and the pinasaco are alloy barrels and the others cast.
Posted: Tue Dec 20, 2011 10:31 pm
by Train Driver
As cezeta bought me the DR kit its the best
but i was going for the pinasaco kit and some tuning work at diablo moto,
give alan a call as he is the top vespa man
Posted: Wed Dec 21, 2011 11:45 pm
by jonny snatchsniffer
the dr is a bolt on kit and pretty basic, the others need the case transfers matched to the barrel and will benefit from more inlet timing, and you should be able to get 14-15hp no problem with a decent pipe and t5/p2 carb with the polini or malossi, i dont know much about the parma or pinasco
the standard crank will be fine, even better with 10-15mm cut off it for more inlet duration
Posted: Mon Dec 26, 2011 1:33 pm
by col68
hi mate I had a dr180 couldnt stop heab leaking and had seized 4 times !!! got a malossi 166 28mm delli simomini pipe and a molossi upgaer kit on my mk1 pxe 4 plate clutch made 15 bhp on dyno never lets me down revs to 7000 70+ mph . col
Posted: Mon Dec 26, 2011 10:11 pm
by AndyS
Is the 166 kit very revvy and not very torquey, or is it ok with the siminini pipe
Does the upgear kit help. and if so which one is it
thanks
Posted: Thu Dec 29, 2011 2:42 pm
by Train Driver
All the details are here give alan a call he is always there
http://scooterotica.org/forum/viewtopic ... 12&t=11096
i think he sleeps under his bench
